Hi Cao,have 2 questions will the camera gimbal be A small sized one and also could it be possible to turn the video on and off with A switch on the T12 thank you
about 20-30g you want to Use air transportļ¼
1ļ¼about 1 month
2ļ¼ok ļ¼ make sure: h.264 , 2M baud rateļ¼ video bit stream ā¤ 0.6Mbpms
yes,very small , but without LEDs
the camera with LEDs is for Sandblasting drone . itās too big for small and high flying drone
It hasnāt been launched yet.
Hi @SKYDROID Cao,
Ok, too bad for the waterproof camera but we will wait
Do you try to send h264 video with Gstreamer with raspberry ?
@silvain have you considered using Silicone Conformal coating to water proof the camera. I have used it a number of times on Cameras, ESC and other devices. Of course you have to avoid the camera sensor and connectors. But the main PCB can be protected from water this way. I have even done Flight controllers. Avoiding the barometer.
Just a thought.
No, for mapping, no so long range as yours, is more than enough the range but give safe control, I love to have always rc control to fly safe. the T12 looks nice to save weight equipment, building time consumption and preflight time preparation.
Just to let every one no the T12 receiver and serial camera are up on AliAlihttps://skydroid.aliexpress.com/store/4474008 Express
Gstreamer with raspberry can be supported theoretically ļ¼make sure: h.264 , 2M baud rate portļ¼ video bit stream ā¤ 0.6Mbpms
brilliant ive got a great system
Wow, great system! What flight controller was used in aircraft /drone ? Live video quality is really good and no jello at all.
Im using the Pixhawk 2.1 cube but it is designed around any f/c that runs ardupilot it is a very good system
Okey. Iām still using M12L system and it works like a charm. Iām looking alternative FC for drone used with M12L. Pixhawk 4 (FMUv5) gets weird problems with almost all RX & TX with using arducopter. and it is not fault of RX or TX, Only with px4 Pixhawk 4 is usable, but px4 itself is really limited maby I should try cube also.
Yea the cube is very good and they now have a mini carrier board https://www.3dxr.co.uk/product/mini-carrier-board/ hope this helps
Im using a pixracer and a X2.1 and try a Pixhawk too with M12 L and any problem.
Hi everyone,
I try to get the RSSI of the remote but the mavlink message is never send by the remote.
Do you know if the drone or the Ground station have to send something to enable it ?
Thanks
Silvain
