Hi everybody,
I have a 6m span glider (ASG29) equipped with a Pixhawk 3 and Arduplane 3.8
I use the Pixhawk manly for safety reasons: when the glider is to far or to high and I have troubles to see it, the RTL mode brings it back.
Every things works perfectly, except that the loiter radius is far too large, about 150m. I have changed many parameters without success. The maximum bank angle is set to 60 degrees, the loiter radius to 10 m and so on… The real bank angle is around 10 degrees.
One thing that might raise turn radius is when the airspeed sensor is not working well , for example if you forget to remove the cap from the Pitot tube the AP will see a speed below ARSPD_FBW_MIN and will prevent sharp turns to avoid stall .
Your ARSPD_FBW_MIN is quite high 18 m/s if the plane speed is under that value it could lead to large turn radius.
BTW your Wp_Loiter_Rad is too small , just 5 meters.
Thank you lucamax for your quick answer.
18 m/s is the normal cruising speed of the glider. Remember it is a 6m span airframe. It stalls at 12 m/s.
I will try with ARSPD_FBW_MIN= 12 and Wp_Loiter_Rad=20
I will give you news as soon as the weather allows to fly.
@Inae you are limiting the vehicle to a 33 m radius bank at sea level (due to the NAVL1_BANK_LIMIT), as you get higher the radius will be expanded past that (although it shouldn’t be possibly expanding you to a 150 meter radius). An actual flight log (dataflash please) would help a lot more for reviewing.
In general ARSPD_FBW_MIN should not be the same as TRIM_ARSPD_CM as this limits TECS strongly.
If the stall speed is 12 m/s I would go for ARSPD_FBW_MIN= 14 and start with Wp_Loiter_Rad=50 then reduce the radius to find what the plane can achieve.
Thank you WickedShell for your fast answer.
The problem seem’s to be solved. During the last flight, I reached a Loiter radius of around 20 m !
I send you an Excel file with the evolution of some parameters during the different flights.
The version of Ardulane is 3.8.5 beta because I use the SPD33 air speed sensor.
The only remain problem is that under loiter, the glider describes a trajectory in eight.
Next flight i will check the 1.12 version of my parmeters to see if it can circle under loiter mode.Evolution paramètres.zip (6.8 KB)
Thank you Lucamax for your answer.
Next flight i will check the 1.12 version of my parmeters to see if it can circle under loiter mode. Evolution paramètres.zip (6.8 KB)
