I have tator frame ( not sure what ) hexacopter with pixhawk. 40A esc and 335kv motors and 2x 4s 5200mah batterys.
Im having few problems. I have 433mhz 915mzh tx that send info to my phone, phone has same rx. After im more than 10m away, phone tells me (signal lost) and I have no information anymore. antennas are correctly, and also I cannot see battery voltages from phone, Im using qgroundcontrol software.
Thats the first thing, not so important.
I have done 10min autotune but in loiter mode or poshold or althold, the quad wobbles around and if I dont change mode to stable, it will start wobblying so much that it crashes.
Even when there is no wind at all, the it is wobblying around, ( stays in one place and does not drift )
Im having good gps, and gps antenna is raised 20cm above the frame.
I have done compass calipration many times etc…
I fly alot fpv drones so im not new to drones, but new to ardupilot and hexacopters.
The wobblying comes from bad PID’s?
How to tune them manually? I have not found any intructions, everyone says “autotune” but its not doing anything (it changed PID’s from default so its changing, but does not affect flying)
Ideas?
Do I need to autotune IN loiter mode?
Because I tuned in alt hold.
