hi,
i am flying a 5kg copter with apm2.6 and current 3.1.5 firmware. i have mounted a lumix gh4 on an three axes brushless gimbal.
in stabilise mode the gimbal works perfect no swinging system and no vibrations from copter parts will affect the gimbal. but if i switch to loiter mode the gimbal starts swinging. imo this is caused from aggressive corrections made from loter and/or althold pid’s.
my copter is well powered, maybe a little bit over powered.
i adjust rate_roll and rate_pitch P to 0.08 to get good performance without oscillations(stabilised mode). all other settings are the default values.
my question is how can i adjust loiter and ald hold pid’s (Throttle Accel, Throttle Rate, Altitude Hold and and maybe Rate Loiter Pid’s in a way that the motors do not make corrections in loiter and aldhold so aggressive?
currently i am not sure which controller works wrong. i read this copter.ardupilot.com/wiki/loiter-mode/#Tuning. but on loiter tuning page i found no answer at all. currently my idea is that my altitude controllers maybe works incorrect.
here is a video which show the problem.
[youtube]https://www.youtube.com/watch?v=B5Xk0v1ncBU[/youtube]
i start flying in stabilize mode. you can see that gimbal works ok in this mode. if i reach target altitude i switch to loiter. and than the gimbal becomes vibrations caused by aggressive corrections made from motors. you can see it very well and also you can hear the motors which will make a lot of fast corrections. i do not mean the first shake caused from switching to loiter. this problem is known an caused if the copter is rising while you switch to alt_hold or loiter. i mean the smaller vibrations in loiter mode after changing mode and while copter is loitering.
