Lifted off in stab. Rock solid hover with next to no movement. flew around a bit then got some height. Switch to loiter mode and position was held good, but copter looses altitude a little then gains it back and so on, but seems to hold position very well. GPS good fix and <1 hdop.
While in loiter mode i tried to move around and its very sluggish and twitches allot. Why is this?
Viewing my own logs i can see i sort of have a issue with vibrations. XY isnt to bad but could be a little better but Z is just in limits but a bit to close to the edges and does go over now and again.
What causes Z vibrations? Props? Nothing is touching the APM board and is mounted on a proper apm holder with rubber stumps each end, will attach picture soon
The altitude issues in loiter is deffo down to vibes but why sluggish moving and twitching? Is it a PID issue or will vibes effect this?
What helped me a lot was to first make sure the props are balanced. I further went as to balance the bells on the motors as well. That made a huge improvement in performance, especially with alt hold and pos hold…There are plenty of videos on that. In your picture the rubber band is just tightening the flight controller closer the vibrations. Hence why it got worst… You may also ain’t to look into some Kyosho Zeal Tape. I have read that a little goes along way. Every frame and setup is different so it’s very difficult to say exactly the problem. I say start with your balancing and check your logs after and compare them to before. I’m sure you will see a difference for sure…
I wonder if the frame is what is vibrating on you… Have you tried mounting the APM without the “shock absorption mount”? I ordered one and ended up removing it and just stuck it down with 3m tape. Just a thought…
I went back and read your whole post… You say you get a pretty good alt hold? Have you done an autotune? The twitchiness could indicate pid tuning as well…
I did get pretty good alt hold but I also has pretty decent vibes. Theno I had a little crash into a tree. I’m starting to wonder if I have damaged a motor or theses props I have are to heavy. That’s all that’s changed since good vibes. Will heavy none flexible probs wreck vibes?
Auto tune is my next thing. Got it doing everything else to a OK standard
