I Have updated firmware to AC 4.0.1 rc3 then I rebooted and I got message that prearm :logging failed
I have changed parameter log_disram = 1(enable).
Is this the first time you’ve seen this? For example does it happen with Copter-4.0.0? Could you try switching back to Copter-4.0.0 and see if the problem continues? Then try upgrading to 4.0.1-rc3 again and see if it continues?
It may also help to clear out the log files and if that doesn’t help try re-formatting the SD card.
Thanks for the report.
I’m not done any thing but there is no message appear now as logging failed.
Thank you.
If none of Randy’s suggestions work, please post a copy of your
parameters.
Peter
Now working fine with beta firmware also I don’t know the reason.
Thank you for your suggestions.
