OK, so several of the empty fields are now documented in the ArduPilot
source tree.
Here’s BARO - which you had an outstanding question on:
// @Field: TimeUS: microseconds since system startup
// @Field: DesRoll: vehicle desired roll
// @Field: Roll: achieved vehicle roll
// @Field: DesPitch: vehicle desired pitch
// @Field: Pitch: achieved vehicle pitch
// @Field: DesYaw: vehicle desired yaw
// @Field: Yaw: achieved vehicle yaw
// @Field: ErrRP: lowest estimated gyro drift error
// @Field: ErrYaw: difference between measured yaw and DCM yaw estimate
// @LoggerMessage: BARO
// @Description: Gathered Barometer data
// @Field: Alt: calculated altitude
// @Field: Press: measured atmospheric pressure
// @Field: Temp: measured atmospheric temperature
// @Field: CRt: derived climb rate from primary barometer
// @Field: SMS: time last sample was taken
// @Field: Offset: raw adjustment of barometer altitude, zeroed on calibration, possibly set by GCS
// @Field: GndTemp: temperature on ground, specified by parameter or measured while on ground
// @Field: Health: true if barometer is considered healthy
And there’s that source code after it has been rendered in our Wiki:
https://ardupilot.org/plane/docs/logmessages.html#baro-gathered-barometer-data
That document you’ve put together is a fantastic resource. It would be
great to get it into our source tree in that markup form you see.
Would you be willing to help put it into the source tree?
Would you mind if we took a chunk of it and put it in ourselves?
I understand you’d like “completeness” in your document. I’ll make an
effort to document the bits you’ve marked in yellow in our Wiki…
I’ve now created this PR:
https://github.com/ArduPilot/ardupilot/pull/13887 which contains the
information you were missing (when combined with the following list…)
BARO: documented in Wiki
CTRL: I think your descriptions are accurate.
FMT: documented in Wiki
FMTU: in PR
MULT: in PR
NKT: in PR
NKT2: this was timing for a second core; it is no longer used
SRTL: in PR
UBX1: in PR
UBX2: as UBX1
UNIT: in PR
jonnybeg
(marco otta)
March 25, 2020, 3:52pm
22
Thank you very much Peter,
i’ve already updated my file with your sudgested link.
Here is the link
I’ll be very happy if you’d like to use it for wiki (as for the comunity)
If i can help in some way please let me know.
ciao
jonnybeg
(marco otta)
May 12, 2020, 6:35am
23
updated list is now online…what a clear explanation!! thank you
graham_new
(graham newton)
December 12, 2020, 3:09pm
24
Thanks for this. Does anyone know what the MAV parameter mean?
Or where to see the mavlink packages in the logs?
Nice Job, you can put the link where to go to see, download
new version of mission planner show the field info when you mouse over in the tree.
eg
Michael_Oborne:
mouse over
Sir, It is working great, But sometimes it not showing any field info. why this problem is comming🧐
