Log Erase through mavproxy not working on Cube Orange with AC 4.0.5
Pixhawk Model - Cube Orange
Version - AC 4.0.5
In my application i am using two mavproxy and the second mavproxy is initiated only i want to download log and erase from pixhawk… for erasing i do the following
Terminal -1
mavproxy.py --master=/dev/ttyPixhawk --out tcpin:0.0.0.0:5790
Terminal -2
mavproxy.py --master tcp:0.0.0.0:5790
GUIDED> log list
GUIDED>log erase all
This works as expected… even the log erase works fine
But if i have many udp outs and a tcp like below
Terminal -1
mavproxy.py --master=/dev/ttyPixhawk --out udp:0.0.0.0:14550 --out udp:0.0.0.0:14551 --out tcpin:0.0.0.0:5790
Terminal -2
GUIDED> log list
In this case logs are not getting erased… and it returns no error… I tried connecting through mission planner on that TCP port of mavproxy and tried erasing… No success
However
If i use 3 mavproxy’s instead of 2 like above then the log erase works fine
Example:
Terminal -1
Terminal -2
mavproxy.py --master tcp:0.0.0.0:5790 --out tcpin:0.0.0.0:5780
Terminal -3
mavproxy.py --master tcp:0.0.0.0:5780
GUIDED> log list
Logs are getting erased successfully by this method…
But i don’t want to use multiple mavproxy instances…
Pls help
