StrLog
(StrLog)
April 25, 2014, 5:03pm
#1
After updating the software, the terminal is no longer available for me to get the logs.
It was there before the update, plus I am getting a solid error every time I launch the app.
Trying to get the vibrations down, but I know this is not the correct process.
This is supposed to be the acc’s selected above.
TCIII
(Thomas J Coyle III)
April 25, 2014, 5:14pm
#2
@StrLog ,
The data flash logs can be downloaded using the Data Flash Log tab under the HUD display in the Flight Data window.
Regards,
TCIII GM
StrLog
(StrLog)
April 26, 2014, 12:11am
#3
TCIII
Thanks, that is probably where I was going.
Now I get this error when I try to get the logs.
StrLog
(StrLog)
April 26, 2014, 12:47am
#4
TCIII,
Thanks found it.
I remember there was a log in the folder from a few days before the update.
Now, no matter what I do to make it save logs, go and preview logs, there is no logs, after flight.
I wish I could rollback, but there is no archive for the APM software.
So, this is the error I get when I connect.
And then when I request the logs to download, this error.
TCIII
April 26, 2014, 2:05am
#5
@StrLog ,
Open the Help window and click on the Check for Updates button. I have updated 1.3.0 at least 3 times since it came out.
Regards,
TCIII GM
StrLog
(StrLog)
April 27, 2014, 1:17am
#6
So I am able to try to get logs, but none seem to be getting saved to the APM.
Here is how I setup. I set to stabilize, and fly for say 2-3 minutes.
Then when I go to download the logs,
What am I missing, if there are no logs stored in the APM.?
StrLog
(StrLog)
April 29, 2014, 1:16am
#7
Is it possible no one has an answer.?
I have gone back and setup to get different log bitmasks, then go fly.
Bring it back in and try to download the logs.
Still get the error no logs found basically to download.
I need some help.
StrLog
(StrLog)
April 30, 2014, 1:02am
#8
Still confused, but making headway.
went to the console, planner and saw the APM had 5 logs stored on it.
no idea why they were not found or downloaded to my tablet.
so on to erasing the logs, and going to recalibrate.
any suggestions?
StefanG
(StefanG)
April 30, 2014, 7:23am
#9
[wf]Tradheli software[/wf]
[mf]Coper/Tradheli[/mf]
