Did u find solution?
I have the same issue:
Test: Compass = FAIL - Large compass off params (X:-158.94, Y:115.60, Z:8.33)
No MAG data, unable to test mag_field interference
My system: APM 2.6, external compass LEA-6H GPS
Mission planner settings: External compass ROLL 180
You should be concerned because only very experienced users who specifically help the developers test the code should fly Beta firmwares and release candidates.
[size=85]For the PX4 and Pixhawk it is OK if the values are greater 150 or less than -150 and it will still arm.[/size]
My log has a Pixhawk Compass value greater than 150, so I gather that is why it is flagged.
If it is okay, per the wiki, then MP shouldn’t be flagging it as a FAIL.
So, assuming the wiki is correct, and MP is in error, then there should not be a cause for concern, and MP is in error.
Yes, I am flying beta firmware, and I feel I am helping the developers by pointing out an issue. What I didn’t know is if it is a firmware issue, Pixhawk issue, MP issue, or wiki issue.
