Locate Copter Alarm
Hello everyone. First of all, I should point out that I am very inexperienced in drones and this is my first hobby and business project. I set up the installation entirely with the information I obtained from the internet.
I created the set using EDU450 Drone, Cube Orange, Here3+ and SIYI MK15 controller.
I don’t get any errors on Mission Planner. But when I try to power the drone in the Ground Control application, I get an error called “Locate Copter Alarm” and I could not find a solution.
I can manually power my engines through the MK15, but I can never move them in flight mode. I’m looking for help regarding this. Thanks.
Note: The design may look very bad, I could not provide a battery yet. I am feeding it via the power supply :smiley:
Move the switch in the left corner surface 8 times. Make sure the GPS is connected
Check the radio calibration, keep both the throttle down while completing the radio calibration
