Live Calibration on DroidPlanner? (danse calibration)
Wondering if “Live Calibration” feature exists in Droidplanner. I am referring to calibration with the “danse” with collecting data for 60sec…
I do that each time I change my flying field location with Mission Planner, but want to know if I can do it with DroidPlanner.
You cannot do that yet on DP, but if you drop your issue at github we can implement the feature:
github.com/arthurbenemann/droidplanner/issues
Thanks for reply Arthur.
I am dependent of this “dancing calibration”, since each time I change my field location 1-2 km away, my quad starts the toilet-bowling effect which is removed only after re-doing the calibration.
I was thinking to go in my vacation with just DP and my Nexus7 only, but it looks I still need to bring the laptop with MissionPlanner to do the calibration.
We will implement that after we are done with the current release.
But it seams that you have a setup problem with your copter. Make sure you mount your GPS at a good location, and run the compassmot feature (if you have a current sensor).
Also you may want to consider an update to the new GPS+Mag module.
