In Mission Planner there is the LIM_PITCH_MIN described as “The minimum commanded pitch down angle.”
I understand this that if I set it to 20 then the plane will dive at a minimum of 20 degrees unless a steeper decent is needed based on the height difference between 2 way points.
This seems to contradict the TECS_SINK_MAX definition “This sets the maximum descent rate that the controller will use. If this value is too large, the aircraft will reach the pitch angle limit first and be unable to achieve the descent rate. This should be set to a value that can be achieved at the lower pitch angle limit.”
Basically, I want to limit any dive to 25 degrees maximum.
