I’m having issues with proximity lidar, I have a Lightware SF45/B, set it up according to the Ardupilot page (https://ardupilot.org/copter/docs/common-lightware-sf45b.html?fbclid=IwAR2nI5SfGk_bnbrrxROG8vg6rwGL8VzGAY_4xX6t0dKnDstrYdTcFOTjx6Y#common-lightware-sf45b).
It is not coming up on the Proximity radar page of Mission Planner. The Cube does not seem to even know its there. I have RX to TX and TX to RX, Its in Telem2 and i set up everything on Serial2. Baud rate of 115200 is set on lidar and serial2. Lidar is working properly as i can see hits on the lightware software. I’m using a BEC to power the lidar and it has a common ground with the Cube. Powers up fine and moves back and fourth as its supposed to.
UPDATE:
After seeing another users settings I noticed he was using Beta 4.1. I’m still on Stable 4.0.7. I tried and it works with Beta 4.1. Does not work with Copter 4.0.7. I don’t have the same menu options under Avoid with 4.0.7 as i do with Beta, no “backup” options. Also, i noticed it only works on Telem1 even though Telem2 has all the same settings.
Another note, while using Copter 4.0.7 the lidar will only start moving if it sees a Mav1 Protocol signal from the telem port when its powered up. Any other setting, i.e. Protocol 11 “Lidar360” it won’t move at all.
Possible bugs? @rmackay9
