I’m thinking of fitting lidar to my Pixhawk plane for more accurate low level flying and potentially auto-landing. A few questions:
Does it work OK over water?
What happens with trees? For example fields - woodlands - fields etc. Would it measure the top of the trees and rise accordingly?
Can it be set at an angle to enable it to look ahead a bit. My plane is quite quick so would need time to react to a rise in the ground or woodland after fields.
Yea it can avoid trees but the accuracy of object avoidance is directly proportional to the type of Lidar you are using and its range. If laser light doesnt bounce back, you are in trouble.
Can it be set at an angle…no…at Speed x u want light to bounce back and u want to catch it.
