Less responsive Pitch/Roll in Loiter vs AltHold/Stabilize
After my Autotune, the controls in Stabilize and AltHold are perfect for Pitch and Roll. When I switch to loiter mode they are less responsive and my Hex rotates at a much shallower angle. Am I missing something?
No, with the current code is normal.
As Marco says it’s normal. In stabilise you’re setting angle with the stick, in loiter you are setting speed with the stick.
sent from my phone so apologies for any typos
[quote=“RabbitStu”]As Marco says it’s normal. In stabilise you’re setting angle with the stick, in loiter you are setting speed with the stick.
sent from my phone so apologies for any typos[/quote]
So I guess the question is what Parameter do I change to make it be more responsive and accelerate faster and go faster (In loiter when using the pitch and roll sticks)?
Sedim,
Increasing the WPNAV_LOIT_SPEED will make it accelerate faster and also make it’s top speed faster I think.
