I’m about to build my second “V2” version of the Hexsoon EDU-450.
On my first one, I didn’t bother with the LED’s that were supplied with the kit.
On this one, I’m going to use the CubePilot carrier board for the EDU-450 - and I thought I’d go ahead and use the LED’s. The carrier board has the GH connectors installed for these lights. I assume they are powered by the built in power distribution. I’m not exactly sure how they are switched/configured - or if they even need to be.
I recall several people using them successfully in the past - and I think I recall something about a LUA script being involved.
To do my research, I though I’d put AI to work - so I asked Microsoft Co-Pilot.
Co-Pilot suggests that all that’s required is setting the BRD_PWM_COUNT parameter to 6 - but this parameter doesn’t appear on the ArduPilot parameter list.
At the risk of seeming lazy, would someone please offer a link to the proper setup for these LEDs?
I’m not interested in any fancy colors or blinking - just standard illumination.
Also - I’m curious about which ports control the LED function. The Co-Pilot dialog suggests its the AUX ports - but it’s response isn’t confidence inspiring.
I’ve actually had some pretty good luck with Co-Pilot on looking up quick “how to’s” on Linux and Metashape. I was less optimistic with Ardupilot - but I thought it was worth a shot in the dark.
As in most things “your mileage may vary” - so your point is well taken.
Do you know if it’s possible to illuminate these lights without a LUA script?
By “standard” I meant just to have them turned on.
The ones specific to ProfiLED discuss using aux outputs (the same as the script). You just change a couple of parameters to use them as “NTF” devices instead of scripted. It’s all there in those links.
Ok, I guess they don’t specifically say “aux” - but on the Cube Orange, you need to use the aux outputs, which are referenced generically as servo pins in the wiki.
