Hi All,
Having searched through this and other forums, I’m still unclear on the functions of A4-A11. So here goes my first post…
Could someone clarify the function of the external LED/outputs A4-A11?
I think I understand some of these. By using the correct mask in LED_MODE A5 can be used to indicate a low battery condition and A6 will indicate the GPS lock. Also we can use the LED_MODE mask to blink either or both the GPS and Motor LEDs when a way point is reached in Auto mode. However, I’m not clear on the function of A4 Aux and A7-A11 Motor LEDs.
Further I see we can change the Low Battery Flash to slow/fast (or oscillate), but not disable it. Which output would this setting affect? My assumption would be just the Motor LEDs, but it could be all of them.
Thanks
Chris
