Droneup
(carlos martinez)
1
Any one intersted in Environment-friendly hydrogen drone?
Model: Four-rotor
Wheelbase: 1060mm
Rack weight: 3.95kg
No-load weight: 7.25kg
Maximum load: 1kg
Maximum takeoff weight: 8.25kg
No-load maximum life time: 110min
Maximum load life time: 80min
Power: 800W hydrogen fuel metal stack + 1050mAh lithium battery
Maximum cruising speed: 10m/s
Maximum climb speed: 2m/s
Wind resistance level: Level 5
Any comment or features we can discuss here.
Eosbandi
(Andras Schaffer)
2
What motor/prop combo do you plan to use ? 800W for 8.25Kg weight with 4 motors seems barely enough for hoovering.
mboland
(Mike Boland)
3
As @Eosbandi points out about power, our machines are that weight and require around 1100W at hover.
800W would be insufficient to hover.
An adequate power system would need to supply 1200W to 1500W to be considered useful.
