what is the largest sd card that works in a H743? or whats the largest you have tried? will 128gb work?
32gb for me. I have a bunch of them so they go in everything.
I’d guess 32GB may be the limit. Many microcontrollers have trouble with extended file systems (beyond 32GB). I don’t have any data to support the ChibiOS limit, though. I’m sure it’s available somewhere.
Yeah, should be 32GB. exFAT isn’t enabled in Ardupilot’s ChibiOS FatFs implementation.
Actually I have found exFAT to work but only experimenting with it. Nothing flying formatted that way. And not on a large drive but that may be irrelevant. Just tried MAVFtv and it’s functional.
Huh, that’s interesting. #define FF_FS_EXFAT
in _ffconf.h is set to 0.
…nevermind, it is set to 1 in libraries/AP_HAL_ChibiOS/hwdef/common/ffconf.h
, just not in the ChibiOS fork repo. So in theory it should work with cards of any size as long as they’re using exFAT.
I have a Matek H743-WLITE and a Pixhawk 6C that both nicely work with a card of size 128 Gb.
I have not tried to fill the entire card with logs, but at least ArduPilot can write logs on these cards, and other operating systems can read them too
Good to know, I plan on leaving my rover on for the next 2 months so i dont want it to run out of space.
