if the OSD output is configured to DJI goggles with WTFOS, the elements can no longer be placed with the editor for the onboard OSD, because there are max. 30 columns available here in the X direction.
For the OSD with WTFOS in HD setting (OSDx_TXT_RES=1), however, at least 50 columns should be available.
Is it possible to enlarge the design area? Otherwise it is a bit tedious to change the element posiions in the Full Parameter List manually.
