I was able to load that log.
MOT_THST_EXPO,0.85
is definitely way too high
- The PWM range for those ESCs is wrong
- Vibrations are too high
Definitely see if you can reduce vibrations before flying more - check in the doco and search through other discussions on how to reduce physical vibrations. This is very important.
I recommend setting all these. I’ve looked over your existing settings and the log file to come up with these. You can copy/paste them into notepad and save as a .param file. Then use MissionPlanner or QGC to load and write the new .param file - this avoids typing errors.
ARMING_CHECK,1
ATC_ANG_YAW_P,4.5
ATC_INPUT_TC,0.2
ATC_RAT_YAW_I,0.08
ATC_RAT_YAW_P,0.80
AUTOTUNE_AGGR,0.1
BATT_ARM_VOLT,44.30
BATT_CRT_VOLT,42.00
BATT_FS_CRT_ACT,1
BATT_FS_LOW_ACT,2
BATT_LOW_VOLT,43.20
GPS_GNSS_MODE,65
GPS_GNSS_MODE2,65
INS_HNTCH_ENABLE,1
INS_LOG_BAT_MASK,1
INS_LOG_BAT_OPT,4
LOG_BITMASK,180222
LOG_DISARMED,0
LOG_REPLAY,0
MOT_BAT_VOLT_MAX,50.40
MOT_BAT_VOLT_MIN,39.60
MOT_PWM_MAX,1940
MOT_PWM_MIN,1100
MOT_THST_EXPO,0.4
PSC_ACCZ_I,0.4
PSC_ACCZ_P,0.2
Use MissionPlanner motor test to check these are still appropriate:
- The
MOT_SPIN_ARM
value has to be for the lowest possible value that allows to motors to start up reliably and smoothly
- Then add 0.03 onto that value for
MOT_SPIN_MIN
Now provided you’ve been able to improve the vibration issue, do a test flight just in AltHold - hover for a while and do some gentle movements and ascents and descents.
Let’s see that .bin log file.
EDIT:
I meant to also say I’ve specified reducing some YAW values so yaw will not interfere with pitch and roll at this early stage.
