I have used pixhawk Cube Orange, dengan fimware V.4.5 and tuning has never been a problem for me. but I’m still confused about finding the right roll, pitch, PID values so that my quadcopter is stable. using a 30" propeller and 12s battery with a frame width of 46". To try to make it stable I have lowered the value of the Roll/Pitch Sensitivity parameter by reducing it by 10% but that is the effect when in loiter mode, and when joistic pitch is played it will experience severe shaking. Please help to complete my quadcopter.
i will attach data.log
on this log I made several flights without removing the battery.
You have the bi-directional DSHOT firmware installed but only using PWM, so unless you have DHSOT-capable ESCs you can go back to the standard firmware. Parameters will remain intact.
MOT_THST_EXPO,0rings alarm bells!
You would have 0.77 for most normal ESCs with 30inch props, or probably 0.6 for T-Motor Alpha ESCs. The MOT_PWM_MAX and MOT_PWM_MIN are likely wrong.
After fixing those you will need to recheck the MOT_SPIN_ARM and MOT_SPIN_MIN values.
OK sir, after I tried it the results have improved a little. but if the pitch is moved forward or backward, what happens to the turbulence in the drone, sir?
Do you mean the copter is unstable?
You would need to follow the tuning documentation - there’s plenty of info in this forum if you search and plenty in the documentation
yes, that’s right, sir. the quadcopter is not as stable. if after there is interference from the roll/pitch joistik.
i have read many forums about tuning large quadcopters. and also follow the instructions methodis. but it hasn’t solved my problem.
I will share my full parameters tomorrow after I return home.
I have attended the event. but I also haven’t found the right settings for my quadcopter. Yesterday I followed method 1 to completion but my drone experienced very strong turbulence.
Your Quad-X seems to have a CG issue. The motors 1 and 3 spin higher, front heavier.
The drone has marginal okay vibration, which is not ideal.
Your mot_thst_expo is still zero.
yes, that’s right, sir. I mot_thst_expo by filling it to 0 because previously I flew many times with a value greater than 0.2 which caused my vehicle to experience strong turbolension.
I followed some settings on this forum. Large copter crash on take off pixhawk cube black
and my quadcopter flies better than before, one of them is entering the value mot_thst_expo 0 , because my quadcopter is the same model as this
if i use the source template with 43 propeller diameter but my quad propellers are 21 inches with TOW MAX 20KG, will this affect the flight performance? Or are there some settings that need to be changed?
