I’ve tuned this copter but still getting 13% motor output difference between fastest and slowest motor. I’ve checked CG, motor level balancing and frame trueness. Everything seems to be in order.
Is there some parameter for that can fix this
Yea, I’ve re-calibrated the ESCs and re-checked that motors are leveled
Yes, its an H frame. I’ve read about the opposite motor directions due to frame flex, which is very visible in this frame, thats why didnt try X Configuration
Thanks for the replies.
I’ve changed the motor mounts completely and now its a whole different design. I’ll test that tomorrow and post the results.
32 inch props need arms and frame structure far more rigid than almost anyone expects. Likely the arms and frame are twisting or deforming in flight and allowing the geometry change.
