I am running Mission Planner 1.3.28.4 build 1.1.5633.31488 and firmware 3.3-rc5. I have made the following changes:
3way switch on taranis set to CH8
Retracts plugged into AUX1
Under Extended Tuning: Set CH8 to Landing Gear
In Full Parameter list RC9_Function is set to 29.
In flight I can manual cycle the retracts but cannot get any sort or auto control.
With switch in center I can arm and engage AUTO and the copter will auto takeoff and fly mission and RTH with nothing happening on the retracts. If during the mission I manually switch the retracts up and then put the switch in the center the copter will try to land without cycling the retracts down. Seems to be an inactive function. I would appreciate any insight.
I have also tried taking off in loiter mode and had no response from auto retracts. Not sure if it was suppose to work in that mode as well.
