Im using servo 9 set to 29 for landing gear.When it reaches altitude for retracting it dosent do anything.
Im using 4.4 firmware on pixhawk 2.48.
@larryaamati, simple answer to your simple questions: you configured soething wrong.
Ok, thats nothing new to you. But how can some help you if you don’t show all your settings.
So I think Log.bin and Param files are necessary to check
Here is the Param file.
rescue1.param (15.4 KB)
I dont have datalog files
SOLVED! I needed to go into transmitter and set Channel 9 in my case.
Thanks for your help…
