I have a problem with my APM 3.2
My parameter “LAND_SPEED” is stuck at 32767m/S… If i change this value to 75m/s in “standard params” and Click on “white params” it show “parameters succeffully saved” and if i disconnect and reconnect the APM, the value of LAND_SPEED come back to 32767m/S !
I can change and save all others params but i can’t change and save this one …
I have already unistall and reinstall mission planner, reset the APM and reinstall the firmware
Thank you for your help
I solved the problem by putting 30cm/s or 100cm/s or 200 cm/s. I don’t know why but when i put an other value than 30,100 or 200 (if i try, 40 or 70 or 130 for example) the value is unsave and stuck at 32767m/S (even in the full parameter list) strange
I guess that is more of a mission planner problem then a fw3.2 problem, therefore solved… maybe it should’ve been moved to a section about mission planner, because I find advanced parameters to do that… I have to use extended or full list…
