The easiest way to avoid the problem with 4.2.2 is to not set the Lat,Lon arguments of the Land command.
https://drive.google.com/drive/folders/1gxNf56KR0s1241iIj4UlmfsAV8ooEslf?usp=sharing
Hi Leonard, I hope you are well. I installed 4.2.3 today. I tried a short auto flight with 1 takeoff, 2 waypoints and land in it. I guess the problem is solved. land worked just fine. Iām leaving the .bin file here. thanks.
I am not sure if it is related, but it has happened to me on several occasions that when sending the Land command flying in manual mode (Loiter) the drone does not decelerate when landing.
The drone has range finder and firmware 4.2.2
When the error has occurred, restarting the drone has fixed it.
The rangefinder has a range of 12 meters, it is configured to reduce the speed of descent to 7 meters.
The rangefinder correctly detects the height.
I do not have logs at hand, if it seems important to you I can look for one.
Please do provide logs.
