i have a hard time connecting the L9R AO(3.3V RSSI) to the mini osd
i use micro pixhawk as a FC so i don’t have I/O’s integrated in the board
the only option that i thought off is to take a PPM ENCODER and connect the receiver channels to it beside 1 channel, in this channel connect the rssi anlog output that the reciever has to arduino that will convert the anlog voltage to PWM and from the arduino go into the ENCODER …and from the encoder output to FC(micropix)
this thread is about XM+ rx… i have it and it does work on channel 16
…but i asked about the L9R …i have micropix that doesen’t have any
analog inputs at all …
does the L9R can be flashed with a firmware the enable a rssi on channel 16
or any other channel ?
