Kakute F7 Gyro Roll reversed
Hi
I have a Problem, the Roll Axis are reversed, in HUD qground and Mission Planner, i have try to Flash More optional Setup, Pläne, Rover and Flash older Firmware with the Same result, i try to change the imu orientation gut suboptimal result, i have the older f7 with the old ICM 20689
Are you sure? Does it look like this when you Roll Right (left side high)?
Roll
I have a tricopter but not flyable, i think the Reverse Roll are the Problem
What’s showing in your HUD is correct for that Roll condition. I think you misunderstand what the horizon in the HUD should show for a Roll.
Yes you have right…my mistache…
