Good day. a new JY RM 3100 magnetometer has arrived. It has TTL / I2C / SPI protocols. by default, it works in SPI mode, in order to connect via I2C, you need to set the I2C address and activate the Enable pin. it is not very clearly described in the documentation. manufacturer support does not respond. here is the instruction for it https://drive.google.com/file/d/1h-Nq1n3PxCxxn9_qnfksme3nev5LY1VG/view?usp=share_link
I will also attach a photo
yes, but the software specified in the instructions does not find the magnetometer and hangs constantly. the support service reads the message, but does not answer anything on this issue, and there is no possibility to connect via SPI. they answered another request and provided a connection diagram, but I’m not sure that it will work.
This seems the schematic. Signal I2C_EN seems internal, so you can try to locate it and check its level with above connection done. It seems generated at J1, which is not clear what it is: you can try to read its markings.
In general, you should try to connect the module to Arduino’s in all connection modes, find or write Arduino software, and see what works.
From the RM3100 datasheet: I2CEN (pin 22) This pin should be pulled LOW when using the SPI interface or pulled HIGH when using the I2C interface.
On the reference design above I2C_EN appears pulled low. So it seems that a user should follow the traces on this PCB and see that I2C_EN goes to two possible resistor locations: one pulling it low and the other pulling it high, and be inspired to move (unsolder/solder) the SMD resistor. Amazing.
I know what’s in the title. There is no serial port option so I was wondering if they were talking about a different board. I don’t think I have seen any Mag’s with serial ports and I don’t think Ardupilot supports it if there was.
