I have two planes giving me the same problem .
Setup 1:
TX16S, Jumper R8, Matek F405, Arduplane 4.0.6, Yaapu Telemetry
Setup 2:
TX16S (Not the same radio as Setup 1), Jumper R8, Pixhawk 2.4.6, Arduplane 4.0.5, Yaapu Telemetry.
In both setups I am getting battery, altitude, attitude, messages& Warnings and RSSI displayed on the Yaapu screens.
In both setups I am not getting speed (air or ground), throttle setting, or waypoint information. On Setup 1 the plane has an FPV with OSD and all the data is displayed correctly there.
The radio in Setup 1 is also used with a Dragonlink connection on another plane and all the telemetry information works perfectly there.
Since these are two different TX16S (latest OpenTx as of a couple weeks ago) and two different R8 radios, but the same issue, I’m guessing it’s either a set up issue or a limitation of some kind. Any help would be appreciated.
Thanks,
