Joystick
I use a Logitech USB joystick to connect my APM (with Xtend900 radio and windows 7). then switch on the joystick function, the servos can work, but after several seconds, the servos are freezed. it seems large data workload for APM, what can I do? Any insight you have into helping me is appreciated. thanks so much!
what baud rate do you have set over the modems?
I think joystick might be flooding the link.
[quote=“meee1”]what baud rate do you have set over the modems?
I think joystick might be flooding the link.[/quote]
the daud rate was set 57,600bps, it seems caused by the radio buffer data accumulation (same problem on Xtend900/Xbee/433), could the mission planner solve it?
And I noticed the xtend signal was reduced from 100% to 60% when I enabled the joystick, if I kept moving the joystick, the xtend signal would be lost.
is there anyone provides his help to me?
you will need to provide a log or something to look at. to see whats going on.
