Hallo, the Joystick setup seems to be unique at Ground Control level; it is possible to setup different parameters depending just on the vehicle type - fixed wing or copter, but it is not possible to setup different configurations related to each single vehicle.
The joystick usage would be much more flexible if the joystick configuration parameters would be related to a single vehicle, thus allowing the same GCS system to be used with multicle vehicles with correct joystick configuration
