Hello, i would like to bring your attention to the joystick function Mount Control. It can’t be assigned to a button, the menu that pops when clicking on Mount Control is empty and i can’t select, neutral, gps, retracted or any other gimbal function.
I think this has been broken for a while now because i recall having the same problem last year.
Release is the latest, updated this morning.7
regards,
Corrado
Any hint from Michael on why it is not possible to map joystick buttons on mount control? It has been broken since i first tried a couple of years ago, is it possible to fix it?
Corrado
please try the latest beta.
the parameter name has changed was the cause
I think i have the latest beta from a couple of days ago, you changed it later than that?
Thank you very much for your answer about the problem!!!
regards,
Corrado
Just tested using latest beta downloaded this morning, still doesn’t work, mapped buttons to mount but they do nothing.
Using menus from the software itself the gimball works, so it is still a problem in the mapping of the joystick buttons. It would be really great to have it working some day.
regards,
Corrado
Just wondering if it is just me doing something wrong or it is still broken.
Corrado
what is the build number you are using?
build number
1.3.6873.27544
It was the most recent yesterday, i see there is a newer one now, should i test that?
please try updating again.
