I have followed the instructions of others on this forum and have successfully programmed an “F4” controller to look like a joystick to Windows - kind of. When I plug it in, the Windows driver wants me to calibrate the “wheel” and the “buttons”. Obviously I don’t have a wheel. I also need 6 ANALOG channels (-127 to +127) that I want to use with MP. I try to calibrate in Windows and then set up the channels in MP, but every time I plug in the joysticks, I get different channels and ranges. The Windows driver works fine with 3 analog channels, but when you add more, things really get screwed up.
Does someone know of a replacement joystick driver for Windows (10/64) that will work every time?
