Hi everyone !
I’m working with a Nvidia Jetson Xavier NX dev kit as companion computer. I would like to connect via GPIO pin a Orange Cube to it. I do the connection and use the program apm.launch
provided by mavros
package to test it. All seems to work fine, no error in program or warning.
So, I would like to test with vision_to_mavros
package, but when I test rostopic echo mavros/state
, there is no connection between the FCU (the cube) and the node. I configure the fcu_url
to /dev/ttyTHS0:115200
, where THS0 is the tty for the cube with my setup.
I saw on another forum that there is a serial console by default on the THS0, so I disabled it to avoid any conflict. So now my /dev/ttyTHS0
is in dialout
when I do ls -l /dev/ttyTHS0
. So it theoretically can accept a communication on this port.
I have also seen some people with the same problem, but I don’t seen any solution.
If anyone has had this problem, please let me know to try to find a solution.
Thanks
Quentin
