I’ve flashed latest plane firmware into pixracer, tried to configure R7, R10 and RSat2. I’ve also checked wiring with this page 3 times. Without any positive result.
In my DS16 basic plane with 3 servos + 1 motor is running. Do I need to configure pixracer itself?
I find this quite worrisome since google gives me nothing I concluded this should be no problem
Just coming back since I found the solution that actually works.
I kept digging and found out that my PX4 is a clone of some kind…further information and the solution for those clone PPM issues is here. I was desperate and gave it a go - even though I dont like it at all - it solves the problem.
I wish all who have troubles with PPM on pixracer steady hand for soldering
Also, all that Mike sugested above is true and must have for Jeti recievers to work. Thanks Mike!
EDIT: Actualy, Pin config has to be set to UDI16ch. Tested with REX7 than it works.
