Hi, I’m back trying to get my omniX rover to work, and am still having issues with getting any motor response. I’ve set up the rover, as the process has been mentioned but get no response.
For example, I tried arming the rover in manual mode, and then moving the yaw stick back and forth. I get no response from the motors, and looking at the logs, it is clear that it receives the rc signal, but sends no servo response.
I was wondering if any one had some solutions to this problem. I am loading both the tlog and the parameters file, in the hope that it may help. omniX.param (14.0 KB)
If you say “all 3 turn” do you mean you only have 3 motors? This would be a omni3 rover, not omniX.
No matter what config, all three inputs should come from spring loaded, self centering sticks. I always interchange RC_Map throttle and pitch for my rovers.
Make sure you have your radio/rc_map setup like this and redo the radio calibration.
When you say if you don’t center the throttle, do you mean when calibrating to put the lower limit of the throttle at the center not all the way at the bottom?
I am still noticing that when moving the throttle, only motors 1 and 2 are active, and that while turning (roll) only motors 3 and 4 are active. Is this by design or is there something wrong with my set up?
If this is an OmniX then all 4 motors should spin when the throttle is raised (or lowered). Probably best to post a dataflash log (to be clear, not a tlog but a dataflash log)
