Dear all,
When I test the balance bot on SITL, I notice some issues.
1. I am not sure whether this issue is come from a design decision or not. The rover does not change its flight mode after finishing a mission when MIS_DONE_BEHAVE is 0 (HOLD) or 1 (LOITER). I could not find such an issue in Rover-3.5.2.
2. After finishing mission, the rover tends to drift without input as shown in the below.
You could reproduce this issue for the following steps:
(1) ./Tools/autotest/sim_vehicle.py -v Rover -f balancebot --console -w --speedup=10
(2) upload a mission
(3) arm throttle
(4) mode auto
(5) mode RTL after the rover finishes the mission
(6) mode auto after the rover is back to the home position
(7) rover keeps drifting during AUTO mode after arriving the final waypoint.
3. When I assign a small value to LOIT_RADIUS, e.g., 0.01, the rover keeps rotating yaw angle.
(2) param set LOIT_RADIUS 0.01
(3) param set MIS_DONE_BEHAVE 1
(4) upload a mission
(5) arm throttle
(6) mode auto
(7) mode RTL after the rover finishes the mission
(8) mode auto after the rover is back to the home position
(9) rover keeps rotating heading angle after arriving the final waypoint.
Test version: 85e1569
Mission:
Logs:
