Hi @Arne-W, the scrollbar works great. Now the page is fully accessible !
However the link issues still persist. Using your 2.0.28-rc1 appimage I could connect without problems and I uploaded the firmware apm2-quad v.3.2.1. Now I tried to connect using your new 2.0.29 appimage (without uploading a new firmware) and, as I commented in my initial post, again the connection seems successful. Again it appears the green box and the stabilized mode at top. Moreover the serial connection seems right since I’m reading the same values as when plugging the flight controler using your 2.0.28 appimage, besides there are no errors in the var/log files. This is, the connection procedure seems is working iddentical in both cases. However in the 2.0.28 case immediately there appears “Downloading Params” and the bar progressing at the bottom left of the SetUp page while in your 2.0.29 app versions (and in my compiled 2.0.28, 2.0.29) this procedure doesn’t start. Checking the log file I see a repeating: “QCCParamWidget: No parameters, re-requesting from MAV”, “src/uas/UAS.cc 2254 LOADING PARAM LIST” and “ApmSoftwareConfig::populateTimerTick() - No Param names from param manager. Sleeping for one second”.
These are the messages that I also obtained before initiating this thread, besides, I also had tried starting Planner as sudo and changing udev rules. But, when working, the connection result looks always the same, and I belive, that in fact, it is right. At the moment, with your 2.0.28 appimage everything is working without any special rule as it happens with your Pixhawk.
I’m very new in this hobby and I have just the experience of few weeks wich mainly I spent reading and seeing many things when I had some time, but I’m pretty sure that with a Pixhawk I wouldn’t have this issue. My flight controller is a (very cheap…) Ardupilot, labeled “Arducopter”, v2.8 with few information in the web and not always positive… The lsusb command and the log file reports and Arduino SA Mega 2560 (CDC ACM) Product 2341, vendor 0010 but it doesn’t look Ardupilot original… Anyway, I hope to have time to continue in this nice hobby and to buy a Pixhaw in the future !
I have a question about the firmware that I’d like to ask you. You changed the Install Firmare screen display from 2.0.28 to 2.0.29. In 2.0.28 it was a matter of choosing the figure of the copter while in 2.0.29 the firmware has to be selected form a list. I know that your 2.0.28 installed apm2-quad v3.2.1 in my FC. However, in 2.0.29 this firm is in an hex file and now, thanks to the scrollbar
, I can see the status info box saying that hex files need of external tools and only *.apj or *.px4 can be flashed. Is there any reason for that ?. Also, I like the current firm I have since it seems it is working fine (although still I’ve not tried to fly…), but, could I also use a PX4 one in my FC ?. In this case, do you know which PX4 should be most appropiate ?
