I am experiencing an issue with controlling a throttle servo via a Lua script on my CUAV X7 Pro Plus running ArduPlane 4.6 Dev firmware. I have set up channel 6 to manage both the minimum throttle position and arm/disarm functionalities. My SERVO2_FUNCTION
in Mission Planner is set to 70 (Throttle)
, and I expected that changes made through the Lua script would allow me to adjust the throttle servo’s minimum position based on the switch’s position on my transmitter.
Problem: The script loads without any errors, but the servo does not respond to commands that should increase the minimum position of the throttle by 10%. Here are the key elements of my script:
lua
local switch_channel = 6
local throttle_servo = 2
local normal_min_pwm = 988
local increased_min_pwm = normal_min_pwm + (2011 - normal_min_pwm) * 0.1
function update_throttle_position()
local pwm_value = rc:get_pwm(switch_channel)
if pwm_value > 1500 then
SRV_Channels:set_output_pwm(throttle_servo, increased_min_pwm)
else
SRV_Channels:set_output_pwm(throttle_servo, normal_min_pwm)
end
return update_throttle_position, 0.1
end
return update_throttle_position()
Questions:
- Is there anything in my approach or configuration that could be preventing the script from functioning correctly?
- What additional checks or settings would you recommend for troubleshooting and resolving this issue?
- Could using one channel for both throttle control and arm/disarm impact the script’s performance?
I would appreciate any help or guidance for further investigation!
