Good day, yes its fully compatible… on while fc you must install it?
Dual compasses will give you good results in redundancy.
If you plan use it on a rover you can look for mRo SAM GPS + IST8308 Mag (Full Size) MRO10037…
Thanks David, I plan to use on it on a Navio2 and maybe also a Pixhawk.
I like the MRO10037 unit. I actually have the similar unit with the smaller backplane antenna and it worked well in both Arduplane and Arducopter applications.
