Most of this in already in 4.1
Hi Andy,
I noticed youāve picked up the PR on this?
Iāve got the 4.1.0 dev firmware installed on my Cube Black - and have enabled the VTX_ENABLE param, but i dont have any param for the VTX_SMA_ENABLE - as @wapophis mentions above.
Keen to give this a go for my TBS VTX. As others say above - happy to chuck some $$ toward the developers for such a great job on all of this.
Cheers.
You just need VTX_ENABLE and appropriate serial protocol, no need for anything else anymore. But you need to build the firmware currently.
Cheers Andy. Forgive my noobness, does that mean itās not currently in the Dev version? Also is there a guide to building the firmware? Not done anything like that before.
Its not currently in the dev version, but I hope to get it merged this week
Smart audio is now merged, but we just need the half-duplex change merged in order for it to work properly
Half-duplex change is merged, so SmartAudio is ready to go! Thanks to @wapophis and anyone else who has contributed to this - a group effort.
Hi Andy,
Whatever I try, SA isnāt working, Iām using ArduPlane V4.1.0dev (c3502689) on a PH4-mini 00190036 31385118 35333837.
The VTX Iām using is a Atlatl-HV 2.3 with SA 2.0 on a Pixhawk 4 mini
|VTX_BAND|0|
|VTX_CHANNEL|0|
|VTX_ENABLE|1|
|VTX_FREQ|0|
|VTX_MAX_POWER|800|
|VTX_OPTIONS|0|
|VTX_POWER|0|
|SERIAL2_BAUD|4|
|SERIAL2_OPTIONS|4|
|SERIAL2_PROTOCOL|35|
When I change for example |VTX_CHANNEL|0| to |VTX_CHANNEL|1| nothing changes on the VTX.
I connected the SA connector of the VTX to the TX of SERIAL1 of the FC and also the power and common ground is connected to the FC.
Do I need a special firmware version to use this? I thought is was already āmergedā
Thanks OJ
When it finally got merged SA was protocol 37 - 35 is ADSB
hi, it require lua scripting? It will work on f405wing?
No lua requirement, it will work on all boards
Hi I have 4.0.1dev at April 9th, is Smartaudio built-in already? Or I need compile myself.
MP 1.3.74.1 build 1.3.7768.13970
Sorry is it is obvious, but Iām new on this
Itās only in 4.1-dev
Hallo Andy,
In my previous message I stated āI connected the SA connector of the VTX to the TX of SERIAL1 of the FC and also the power and common ground is connected to the FC.ā
This statement was wrong itās SERIAL2 not 1, I configured everything on SERIAL2.
Even when I changed SERIAL2_PROTOCOL = 37 SA still isnāt working do you know if anybody tested this successfully already?
Thanks for the answer
Other people have got it to work. Try changing the baud to 4800.
Sorry that is the version I have, how access to SA menu? Sorry by make this stupid question
Too bad it isnāt working despite the fact you say itās working for other people, I checked everything 20 times to be 100% certain not to make a mistake and everything is correctly wired and configured, but I can confirm for 100% it isnāt working on a Pixhawk mini on serial2 with an Atlatl HV.
I even configured an old F3 FC with Inav to confirm Smartaudio is working on the Atlatl HV and it does work perfect in Inav.
I spend many hours to get this to work, so everybody else with the same setup, donāt waste your time on this!
Sorry I would have to get one of those VTXās to try. Unfortunately it seems everyoneās version of smart audio is slightly different. All my testing has been on TBS kit.
I ordered a TBS unify 2 weeks ago already when Iāll get it I will test it again and let you know the results.
