Yes, excellent that at least we know and can return them.
Itās good that at least we have spare parts.
Amazon still hasnāt shipped a replacement.
But Iāve finally got my paws on an ArduCopter Journey and compared it to the SE I havenāt yet returned.
What Iāve learned:
The Journey SKYVIPER hotspot on the 2.4G band with the last 3 bytes of the MAC address portion of the ssid is displayed in hexadecimal vs the Journey SE which is on the 5.8G band and the mac address is displayed as decimal. This, I think, makes things easier for customer support. But, also, the switch to 5.8G may have solved some video performance issues?
SKYVIPER AP is at 192.168.99.1 on Journey and 192.168.80.1 on SE.
There is no website access on SE at 192.168.80.1 on port 80 or 8080
The open port scan on both units shows a very different profile
SkyViper SE (without ArduPilot)
SkyViper Journey (with ArduPilot)
The Journey is able to get a GPS fix consistently and rapidly on the floor of my livingroom. The SE was unable to lock GPS indoors no matter how long I waited. So I checked it outside and the SE was still unable to lock. Not sure why.
The Journey SE seems to be a US only product as I watched it move from Kent, WA to here in Canada, it has no mandatory French language on the packaging and the SE app retrieved by scanning the barcode says it is not available in my area. So not usable out of the box for me.
You can tell the Journey SE from the Journey by looking at the transmitter model number. I left the quad itself connected to the packaging so I couldnāt look underneath. Or take it apart. The FCC # is 24G on both so the telemetry is of course still 2.4G but the video/phone app hotspot is now 5.8G only, it seems. Nonetheless, the SE TX refuses to pair with the original Journey and vice-versa which would also be the case if both were the same model, so no new info there.
Journey SE
Journey
Some of the yellowing I mentioned above. Journey on top, SE underneath.
Anyway, the hardware is obviously different at least one way (video/app radio frequency band) so it is not so simple, although the SE platform may well deserve a port? What I would say is that the original unit is imo a great value and anything the community can do to stop them being land-filled one by one by the uninformed may be worthwhile.
Thank you for the detailed comparison.
Original Journey also listens on ports 2017 thru 2022. It would be best if you could do a full port scan with nmap -O -sV
to give some hints about which services are listening there and which OS.
Maybe thereās still an ArduPilot there but the Sonix board was surely replaced based on your findings.
You could try launching wireshark to sniff WiFi packets between the app and the SE. It might be using MAVlink.
Yes, as I just read through I realised that tool had only scanned the well known ports. I also wondered why I wasnāt using nmap and whether I should go deeper with wireshark. Iām new to RC and still on the steep part of the learning curve. Thanks for the reply. Iāll have a look.
Okay, I did all this stuff weeks ago and was just repeating the final steps and now I remember why I didnāt use nmap and wireshark. This windows box only has 2.4G wifi. So I discovered that the SE was on 5.8G because it didnāt show up here. And thatās why I went to the android app. Didnāt think of the pi. Thanks for prodding me lol. Iāll spend some time with wireshark when I get a chance. Hereās what nmap running off of a pi4 outputs.
$ sudo nmap -O -sV 192.168.80.1
Starting Nmap 7.70 ( https://nmap.org ) at 2022-01-12 15:50 MST
Nmap scan report for 192.168.80.1
Host is up (0.0023s latency).
Not shown: 995 closed ports
PORT STATE SERVICE VERSION
21/tcp open ftp Stupid-FTPd
554/tcp open rtsp Sanyo VCC-HD2300 webcam rtspd
3333/tcp open dec-notes?
5001/tcp open commplex-link?
8080/tcp open http-proxy
2 services unrecognized despite returning data. If you know the service/version, please submit the following fingerprints at Nmap Fingerprint Submitter 2.0 :
==============NEXT SERVICE FINGERPRINT (SUBMIT INDIVIDUALLY)==============
SF-Port5001-TCP:V=7.70%I=7%D=1/12%Time=61DF5B49%P=arm-unknown-linux-gnueab
SF:ihf%r(WMSRequest,1,ā\tā);
SF-Port8080-TCP:V=7.70%I=7%D=1/12%Time=61DF5B49%P=arm-unknown-linux-gnueab
SF:ihf%r(GetRequest,24,āError\x20unexpected\x20end\x20of\x20transmissionā)
SF:%r(HTTPOptions,195,āHTTP/1.1\x20400\x20Bad\x20Request\r\nContent-type:
SF:\x20text/html\r\nConnection:\x20close\r\n\r\nBad\x20Reques
SF:tYour\x20browser\x20sent\x20a\x20bad\x20request
</b
SF:ody>HTTP/1.1\x20501\x20Not\x20Implemented\r\nContent-type:\x20t
SF:ext/html\r\nConnection:\x20close\r\n\r\nNot\x20Implemented
SF:The\x20server\x20either\x20does\x20not\x20recognise\x2
ā)%r(RTSPRequest,195,"
SF:0the\x20request\x20method,\x20or\x20it\x20lacks\x20the\x20ability\x20to
SF:\x20fulfill\x20the\x20request.
SF:HTTP/1.1\x20400\x20Bad\x20Request\r\nContent-type:\x20text/html\r\nCon
SF:nection:\x20close\r\n\r\nBad\x20RequestYo
HTTP/1.1
SF:ur\x20browser\x20sent\x20a\x20bad\x20request
SF:\x20501\x20Not\x20Implemented\r\nContent-type:\x20text/html\r\nConnecti
SF:on:\x20close\r\n\r\nNot\x20ImplementedThe
")%r(FourOhFourRequest,24,āError\x20unexpe
SF:\x20server\x20either\x20does\x20not\x20recognise\x20the\x20request\x20m
SF:ethod,\x20or\x20it\x20lacks\x20the\x20ability\x20to\x20fulfill\x20the\x
SF:20request.
SF:cted\x20end\x20of\x20transmissionā)%r(Socks5,A2,āHTTP/1.1\x20400\x20Ba
SF:d\x20Request\r\nContent-type:\x20text/html\r\nConnection:\x20close\r\n
SF:r\nBad\x20RequestYour\x20browser\x20sent
ā)%r(Socks4,A2,āHTTP/1.1\x2040
SF:x20a\x20bad\x20request
SF:0\x20Bad\x20Request\r\nContent-type:\x20text/html\r\nConnection:\x20clo
SF:se\r\n\r\nBad\x20RequestYour\x20browser\x
ā)%r(GenericLines,A2,āHT
SF:20sent\x20a\x20bad\x20request
SF:TP/1.1\x20400\x20Bad\x20Request\r\nContent-type:\x20text/html\r\nConne
SF:ction:\x20close\r\n\r\nBad\x20RequestYour
ā)%r(RPCChe
SF:\x20browser\x20sent\x20a\x20bad\x20request
SF:ck,A2,āHTTP/1.1\x20400\x20Bad\x20Request\r\nContent-type:\x20text/html
SF:\r\nConnection:\x20close\r\n\r\nBad\x20RequestYour\x20browser\x20sent\x20a\x20bad\x20request
ā);
MAC Address: E8:D2:A4:48:90:20 (Unknown)
No exact OS matches for host (If you know what OS is running on it, see Nmap OS/Service Fingerprint and Correction Submission Page ).
TCP/IP fingerprint:
OS:SCAN(V=7.70%E=4%D=1/12%OT=21%CT=1%CU=31098%PV=Y%DS=1%DC=D%G=Y%M=E8D2A4%T
OS:M=61DF5BEF%P=arm-unknown-linux-gnueabihf)SEQ(SP=10%GCD=1%ISR=5D%TI=I%CI=
OS:I%TS=U)SEQ(SP=16%GCD=1%ISR=5D%TI=I%CI=I%II=RI%SS=O%TS=U)OPS(O1=M5B4%O2=M
OS:5B4%O3=M5B4%O4=M5B4%O5=M5B4%O6=M5B4)WIN(W1=FAF0%W2=FAF0%W3=FAF0%W4=FAF0%
OS:W5=FAF0%W6=FAF0)ECN(R=Y%DF=N%T=FF%W=FAF0%O=M5B4%CC=N%Q=)T1(R=Y%DF=N%T=FF
OS:%S=O%A=S+%F=AS%RD=0%Q=)T2(R=N)T3(R=Y%DF=N%T=FF%W=FAF0%S=O%A=S+%F=AS%O=M5
OS:B4%RD=0%Q=)T4(R=Y%DF=N%T=FF%W=FAF0%S=A%A=S%F=AR%O=%RD=0%Q=)T5(R=Y%DF=N%T
OS:=FF%W=FAF0%S=A%A=S+%F=AR%O=%RD=0%Q=)T6(R=Y%DF=N%T=FF%W=FAF0%S=A%A=S%F=AR
OS:%O=%RD=0%Q=)T7(R=Y%DF=N%T=FF%W=FAF0%S=A%A=S+%F=AR%O=%RD=0%Q=)U1(R=Y%DF=N
OS:%T=FF%IPL=38%UN=0%RIPL=G%RID=G%RIPCK=G%RUCK=G%RUD=G)IE(R=Y%DFI=S%T=FF%CD
OS:=S)Network Distance: 1 hop
Service Info: Device: webcam; CPE: cpe:/h:sanyo:vcc-hd2300OS and Service detection performed. Please report any incorrect results at Nmap OS/Service Fingerprint and Correction Submission Page .
Nmap done: 1 IP address (1 host up) scanned in 199.51 seconds
there seems to be an HTTP server listening on 8080. Have you tried pointing your browser to http://192.168.80.1:8080 ?
And 554 is used for RTSP like the 2450GPS and Journey but the path might have changed.
BTW you didnāt scan the full port range with that command, youād have to add -p1-65535
to the parameters (it will take a while).
Port 21 is open too. Have you tried with an FTP client?
To sniff WiFi with wireshark/tcpdump youād have to put the card on monitor mode, idk if the RPi supports that.
Alternatively you can try setting up a fake AP for the app to connect to.
Yes, I tried and it just times out on 8080. Iām guessing itās probably some sort of proprietary command set wrapped in http, given the response that nmap produced contains a stock error message saying āYour browser sent a bad requestā although that may be what nmap does to try and determine OS. Maybe you know for sure what itās doing? Iām a little to busy to dig it out.
Sorry, I just entered the nmap command as you specified. Iāll rerun everything and try to connect to FTP 21 as well and see if I can get at an RTSP stream with VLC and the /media/stream2 url as well.
Haha that was why I said Iād do the wiresharking another time as Iām aware that Iāll have some setup to tackle lol. Apparently prolific mode is available on wired ports but Iām not sure about wireless. I checked today and Amazon wants it postmarked by Feb 1 for return so I have some time.
I also just scanned the Ardupilot developer page for the Sky Viper and see a technique for having the Sky Viper attach as a station to an AP by putting a text file on the sdcard with AP details. I may try doing that as well as it might be something the techs would want to be consistent across all firmware. Iāll try it on my Ardupilot journey too so that I know it works there. Nice to have both units at the same time. WHich reminds me I should do a full nmap scan on it too while Iām at it.
Okay so if thereās anything else you can think of let me know. It will be few days before I get back to it. Cheers!
Set up your Pi as an access point with the same name as the JourneySE, start sniffing and let the app connect to it.
TBH I think Iām almost done with this drone as Iāve answered the question of whether it was hardware compatible enough for a simple firmware set swap. This was when I wasnāt sure Iād ever get a non-SE unit. To me, the SE is looking like any other manufacturerās drone now that I know itās not so easy. As I mentioned above, I canāt even get the SE app youāre suggesting I use (without jumping through some hoops). Iām grateful that SkyRocket released the original ArduPilot products and I realise that the low end drone market is brutal (local hobby shop wonāt carry ANY quads but DJI) so I respect their SkyRocketās attempt to pivot. And maybe what weāve done here so far will help them because they wonāt get unnecessary tech support calls from people who are confused, especially if a used unit they get/buy without packaging isnāt working as expected. Iām curious but definitely not enough to keep it and try porting to it. And, as new, itās too expensive to keep for parts, but at least knowing what Iām looking at will help me if a used/broken one comes along for cheap.
P.S. Iāve solved my 5.8G problem by ordering a $4 USB dual band WiFi dongle but who knows when that will show lol although I guess theirās no guarantee that it will do monitor/prolific mode. Although probably not necessary for this.
A telling description taken from an ad on Kijiji that showed up yesterday:
āJourney Pro Video Drone. Excellent working condition. Tried a couple of times but too advanced for my son.ā
Odds are it wonāt, you shouldāve checked that before buying. But you could raise the fake AP at 2.4GHz and the app probably wonāt care if itās not 5.8G and will try to connect, then listen for connection attempts.
Thereās a chance the thing can speak MAVlink, and we donāt know for sure if itās running some version of ArduPilot on the FC.
When you connect thru WiFi with the Journey you are not connecting to the FC but to the companion board.
It may be that they couldnāt source anymore the Sonix board and had to replace it with something else, but the FC is maybe the same.
I think it would have allowed me to connect to the AP of the SE which then would have given me access to the not-sonic board for more testing. As it was I couldnāt even see it from my windows box but Iām assuming the cheapo dongle would have allowed a simple AP connection. I must say it annoyed me that I had to stop at that point so Iām glad I will have 5.8G capabilities for when this type of thing happens. I didnāt even have wireless turned on because this box is wired.
Yes, the FC could well be ArduPilot but it could just as well be CleanFlight(ClearFlight?) as I think Iāve read elsewhere. Itās not hard to recompile existing code for different platforms especially if you already have a product line and expertise with a other FC software. Doing so means eventually not having to support multiple environments which can really simply (lower cost) tech support. Anyway I canāt even run the app or connect to it easily at the moment so I donāt think Iām the guy to take this one any further. The SE isnāt even supposed to be available in Canada; I got it by mistake. Eventually someone will have one they actually own to dig into because they canāt return it. Iāll just pick up a non-SE Journey used if I want another and spend time on the many other distractions of RC lol If things change Iāll post here
Heheheā¦ Iām still here and lurk, but Iām not of any use anymore, Iām afraid.
I wasnāt even aware they were doing an SE versionā¦ LOL.
Basically, the SkyViper team was let go after we launched Journey. I guess we did such a good job, they felt like we didnāt need to iterate further and they just planned for multiple years of churning out the same product over and over. From then on, it just becomes a game of ālet China find a cheaper way to make itā and that tends to lead to cheaper parts that were promised to work āexactly like the originalā but as we all knowā¦ they do not.
The v2450 GPS was still the one Iām most proud of. That had TaoGlass receivers, etc. The Journey performed well, but not AS good, due to the cheaper components. I have NO IDEA whatās inside an āSEā.
Sorry!
-Matt
Itās a good craft, I still have one and fly it occasionally.
Sorry for doubting you, thanks for the reply!
Thanks for coming out of lurk mode and commenting! Great to get a little background. Nice job on all of it, BTW. But NOW you tell me that v2450 is better LOL! Good to know that I shouldnāt shy away from owning one. Shame they didnāt go upmarket instead of canning the team. It sounds to me like the whole ājourneyā would make a great business school case study.
Itās a good little craft for what it is. I quickly switched to a Orange DSM2 module and flew it with my Taranis, these days I have a Radiomaster which works equally well. Getting the protocol to operate is a bit fiddly but it works.
Does it fit inside? Because I was wondering what to do when I get a name brand transmitter. And, of course, what transmitter I should get. Iām reluctant to go too crazy on a tx because Iām not sure how deep Iām going to get into RC yet. And Iām more into robotics than the actual flying myself. Although that might change! Thatās why Iām starting with the SkyViper GPS units. Perfect to try flying and GC until I know better.
P.S. Amazon shipped the Journey Iāve been waiting for this morning, from Californiaā¦
The Multi Protocol Module in the Radiomaster supports the protocol directly with the existing receiver. Or a Multi Protocol JR bay module would work as does a Hobbyking Orange DSM2 module (if they still make that).
The video stream you can get on a laptop with Mission Planner although I never bother to use it.
