Hello!
I am working on a drone project which I originally wanted to use INAV for, but it seems to be too complex for inav and I want to try to use ardupilot.
I already bought a t-motor F7 pro controller - is there any chance I can load ardupilot on it?
No. F722 doesn’t cut it.
Is this still the case?
This F722 by T-motor says it has 16MB of flash (for logging), is it still no good?
What’s the criteria? Thanks
FC
- Input Voltage: 3-6S
- Gyro: BMI270
- Master chip: STM32F722RET6
- Flash: 16MB
- BEC: 5V 2A, 10V 2A
- Mounting hole: 30.5x30.5mm
- Weight: 8.4g
- Size: 37x37mm
- Firmware: TMOTOR F7(Betaflight)
No good. Logging Flash doesn’t do it.
That STM32F722RET6 chip only has 512k of flash memory - half that of an old limited 1M Pixhawk for example.
So there’s no firmware build that could fit in that.
The 16MB of flash for logging is separate and not used for firmware.
