Hi ,
I’m not sure where I should post my request for help in IRIS or in APM 3.1,
I apologies if this location is not the right one.
I have an IRIS with 3.1.5 firmware and for an unknown reason my Circle mode is NOT working.
I’m so frustrated that I’m not sure where I should look…
I have done the firmware updates successfully (as per YouTube, and manual tutorials),:
- install IRIS parameters with the front GoPRO ( I have a brushless gimbal front mounted).
-wizard steps all completed without any issues…Radio Calibration, Mag Calibration all 9 yards.
-circle radius set a 400 cm (4 m).
-all flight modes checked.
On the field, when I flip the switch to Circle …the quad for a second is orienting the front towards the centre of the circle but instead is taking a diagonal back- left flight path …and keeps on going.
I have tried flipping thru all flight modes with the same result…
I have tried the same flight mode from DroidPlanner 2, and Andropilot with the same results.
RTL mode is working, and I have 10 sat on GPS .
This flight mode works beautiful in spring…with a radius of 500cm (5m)…this would be the only difference…and I will try the new radius over the weekend….
But I can’t see a reason not to work for other radius.
I have uploaded the content of my micro SD from PIXHAWK, and photos of my IRIS at the following location.
dropbox.com/sh/jn4u0kj7rh9e … 89meSryHya
I appreciate any input or piece of advice.
Thanks
