IR-Lock Precision Landing with direct sun!
Hi!
@ThomasSFL
I have a problem when I use the skycharge base with the IR-LOCK precision landing. IR-Lock use a beacon on the floor and a camera on the drone, and on the ground works perfect! But we area having issues at mid day, when the sun its over us almots 90° to the ground. The SkyCharge base reflect the sun like a mirror, and to the eyes of the camera, the beacon its dificult to see. Here its a picture from the problem.
here its what the camera see:
Any idea of how to make it work together with direct sun?
Thanks!
I have never used IR Lock but I am curious if you can get a polaroid filter in front of the lens. That’s what we use in photography to stop this problem.
Good Day,
You should not use mirror-like surfaces directly behind the MarkOne Beacon.
It is best to use matte (non-smooth) and NIR absorbent (typically black) surfaces. Some reflection is ok, but a large mirror-like surface is definitely not good to use directly behind/beside the beacon. It will oversaturate the sensor in the area of desired detection, which results in zero detection if that is where the beacon is located.
Best,
Thomas
great idea, we will try it!
thanks!
hi, i wanted to know how was your experience with it in direct sunlight after changing the back plate
If you assure to not have any reflective material near to the landing port, the system will work great.
What about the ranger finder, which one did you use, does cheap ones work? Im planning on using Benewake TF02 / TF03 lidar.
TF MIni from benewake works ok.
thanks for the help mate
Any idea if F405-based boards (speedybee F405 V4) support precision landing? or do I need to switch to something more powerful like H7
I couldn’t find PLND_ENABLED in the parameters list (I don’t have the pixy cam attached at the moment)
May be you can try in the builder FW site
If That is the board, seems to you can add the PLND
your board is there:
I have yet to try it, thanks for letting me know, i had no idea this was an option
