Hi guys,
I can’t for the life of me get the IR Lock sensor to stop giving the above error. I’ve checked that the i2c cable is okay and have a sonar rangefinder connected that is working OK. The Pixy cam detects the IR beacon just fine when I connect to it via USB and PixyMon. I’ve tried each of the PLND_BUS parameters (default, external and internal). I’m using an external I2C splitter but I’ve tried connecting the Pixy directly to the Pixhawk as well. Still no luck.
I guess at this point I’m on the verge of just giving up. Just wondering if one of you guys have something else I can try?
Much Thanks
