Are there any current ground station software that can run on iOS devices? Seems all the references I found through wiki search are either obsolete or deprecated. Is this due to difficulties interfacing with iOS library?
QGC used to work. Try a post over on the QGC Discord channel, you will most likely get a reason why it’s not supported now.
